No forward or reverse gears
40,000 MILES
JOHANN NAUDE
  • 10 POSTS
Drove vehicle stopped at a stop light when i wanted to drive again no forward or reverse gears. Had to tow it in.
Jan 21, 2020 at 9:40 PM
Good morning,
Did you check the fluid level to be sure it is up to the correct level?
I need more information. Is this the HD?
What engine? Gas or diesel?
Jan 21, 2020 at 10:15 PM
JOHANN NAUDE
  • 10 POSTS
Yes, checked fluid level and fluid nice and clean no smell to it .Checked connections to motors (I think it is motors) nice and clean.
Jan 22, 2020 at 12:34 AM
JOHANN NAUDE
  • 10 POSTS
Sorry guys it's a diesel tiptronic?
Jan 22, 2020 at 12:36 AM
Hello again,
A common issue with these that I have found is the torque converter hub. The torque converter seizes and breaks the hub. That will give you no forward or reverse.
Jan 22, 2020 at 12:43 AM
JOHANN NAUDE
  • 10 POSTS
Thank you makes sense. can hear something engage when i put it in gear. I appreciate your help.Will pull gearbox and let you guys know what i found.
Jan 22, 2020 at 3:15 AM
Sounds like a plan.
You are welcome.
Always glad to help.
Jan 22, 2020 at 3:45 AM
