No forward gears or reverse
103,000 MILES • 1.9L • 4 CYL • 2WD • AUTOMATIC
MIKES SATURN
  • 5 POSTS
Car was driving and shifting fine, parked it. next morning went to move it and no reverse it would not engage and the shifter cable moves at the shifter and at the transmission plus no forward gears would engage rpm changes when you move shifter through the gears and increases in neutral as its supposed to.
Things i have done already is checked the electrical plug on top of transmission and all good, nothing burned and no fluid inside looked like new. also, i checked with a ohm meter all five of the solenoids all between 4.8-5.2, checked them three times. fluid level okay but fluid looked old barely pink color the car ran and shifted fine without any issues after the valve body and re-torquing episode a year ago. except, one time the service engine soon light came on. the TCC lock-up code i do not remember the code number i just cleared the code with my actron code reader light never came on again. this happened about a month ago. everything i have checked so far has checked out fine. any suggestions on what to try? i am stumped. i am a mechanic and this does not seem logical from all gears working fine next day no gears fine. i am ready to do whatever necessary on my end if you can help me. Thanks, Mike
Less than a year vago replaced the valve body and re-torqued both input and output nuts.
Feb 19, 2018 at 6:29 AM
Good evening.
From your description, I would check the filter and see if it is clogged.
If it is good, then you either have a bad torque converter or bad front pump not allowing pressure build up.
Feb 19, 2018 at 6:42 AM
MIKES SATURN
  • 5 POSTS
New spin on filter. how do you test torque converter? i am not sure you can, can you?
Feb 19, 2018 at 7:45 AM
MIKES SATURN
  • 5 POSTS
Is there a regulator for the line pressure?
Feb 19, 2018 at 7:47 AM
You would need a set of gauges to hook up to check main line pressure. there are taps on the transmission for access to pressure tests.
there is a pressure valve in the valve body for main line and throttle pressure. the pressure comes from and starts at the front pump. No front pump operation, no pressure.
Feb 19, 2018 at 7:51 AM
MIKES SATURN
  • 5 POSTS
Is that inside or outside of valve body? do i have to separate it or not? Thanks.
Feb 19, 2018 at 8:15 AM
It is inside the valve body, if you are referring to the pressure and throttle valves.
Feb 19, 2018 at 8:17 AM
MIKES SATURN
  • 5 POSTS
Now the car will not even crank over and battery is 12.5 volts it just keeps getting better, "joking ".
Feb 19, 2018 at 8:19 AM
When it rains, it pours. LOL
Feb 19, 2018 at 8:21 AM
