no fire to the spark plugs
1996 CHRYSLER CONCORDE
100,000 MILES
CHRIS GRANGER
I was checking to see why my engine will not start and I found that there is no fire at the plugs. What could be the problem?
May 7, 2016 at 7:34 AM
  • 55,433 POSTS
Hey Chris,
The first thing I would suspect is the crankshaft angle sensor, they are prone to failure. Fist check the ignition fuse int he panel, next see if the injectors have pulse.
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
if not then the cranks sensor would be the first place I would check
let me know what you find
Best, Ken
May 8, 2016 at 4:46 AM
