Does not start after replacing the timing chain?
140,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
MICHAEL GONYOU
i installed a timing chain. afterward it won't start.
May 22, 2023 at 6:31 AM
  • 110,251 POSTS
Are you sure the chain is properly installed (timing marks)? See pic 1.
Also, could you record it cranking and upload it for me to hear? I should be able to tell if it is a timing issue or a compression issue by listening to it.
See pic below.
May 22, 2023 at 1:19 PM
