No fire in two cylinders?
180,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
RAMIREZ05
  • 6 POSTS
Hello, I have an issue with my van starts, and running rough. no fire in two cylinders have checked for broken wires and connectors all look to be good. Any help would be greatly appreciated.
Oct 17, 2022 at 4:42 AM
  • 110,248 POSTS
There is a chance it is the coil. This design fires two cylinders at the same time, one on a compression stroke and the other on an exhaust stroke.
The PCM is what provides a ground path based on which pair needs to fire. So, if you could let me know which two are the problem, I can check to see if they are functioning from the same tower on the coil and signal from the PCM.
If you aren't sure, have the computer scanned. Most part stores will do it for you free of charge. Here is a quick video showing how it's done:
https://youtu.be/b2IJGfImVvw
Oct 17, 2022 at 11:19 AM
RAMIREZ05
  • 6 POSTS
I have already changed coil pack since the original had a crack in it cylinders 3 and 6 are not firing all others fire at the right time. I have checked the wire harness and connections they seem to be okay. I did notice the wire that plugs into the coil pack for those two cylinders has no juice going into the coil pack.
Oct 17, 2022 at 1:50 PM
  • 110,248 POSTS
The power supply is provided via 1 wire, a brown wire with a white tracer. From that point, a ground supply is provided to different parts of the coil to complete a circuit and create the spark.
Take a look at the pics below. Is it the brown/white wire that has power? Which one are you saying doesn't have power?
If you have a new coil and power to two of the towers, it sounds like the PCM isn't providing a ground path to complete the circuit.
See pic below.
Oct 18, 2022 at 12:55 PM
RAMIREZ05
  • 6 POSTS
Fused ASD has power when key forward blue and orange does not other two also have when running I checked using an LED test lamp and voltmeter.
Oct 19, 2022 at 4:40 AM
  • 110,248 POSTS
The brown/white wire is the power source. The other three are ground paths to the PCM. If you are checking them when it's running, that is why it is showing power.
That indicated there is no ground path for the dark blue/orange wire. No ground, no spark to the plugs.
So, first check the condition of the connector shown above. Make sure pin 1 (see pic above) isn't corroded, damaged, or pushed in, and the wire isn't damaged.
If that checks good, then you need to go to the PCM connector 1, Pin 7, and inspect it the same way. If it is good, then with the connector back on the PCM and the engine running, check that wire to see if there is a ground path being supplied. If there isn't, the PCM has failed. If there is, there is an open in that wire between the coil and PCM.
Let me know what you find. Also, the C1 connector will be solid black.
See pic below.
Oct 19, 2022 at 11:03 AM
RAMIREZ05
  • 6 POSTS
Sorry for the late reply. What would be the best way to test connector 1 pin 7 on the PCM?
Oct 21, 2022 at 1:09 AM
  • 110,248 POSTS
Disconnect the connector at the coil. Using a test light, clamp one side to the battery positive. Probe the aforementioned wire (ground path) with the opposite side and crank the engine. If there is a ground path, the light will pulse on and off.
Oct 21, 2022 at 1:37 PM
RAMIREZ05
  • 6 POSTS
#1 Blue and orange wire no pulse other two #3 and 4 have pulse should the wire at PCM be the same color blue and orange.
Oct 23, 2022 at 8:17 AM
  • 110,248 POSTS
Yes, it should be the same. Hopefully, it is just corrosion preventing the signal. Whatever is preventing the pulse is the cause of your problem. I have a feeling the connector is bad at the PCM or corroded.
The connector will be solid black in color. It's connector one. The wire is dark blue with an orange tracer at both ends. I attached a pic below showing which pin to check.
Oct 23, 2022 at 9:27 AM
RAMIREZ05
  • 6 POSTS
My apologies for the late reply, the weather has been bad over here, so I haven't worked on the van. I got the PCM looked at they said it had a bad coil driver it was repaired i put it back in and the same thing happened no spark at 3 and 6. does the wire from coil pack 3 and 6 run directly from coil to PCM?
Nov 10, 2022 at 12:58 PM
  • 110,248 POSTS
I'm sorry to hear that it didn't take care of the issue. To answer your question, yes, they wire directly to the PCM. I attached a pic below showing the wiring.
Originally, I was thinking you had a bad connection, a broken wire, a bad pin in the connector, or something similar.
At this point, we know the coils are getting power. So, that leaves the wiring between the coil and PCM. Or they didn't fix the coil drivers. What you should do is check the wire between the coil and PCM for continuity to make sure it is complete and doesn't have excessive resistance.
Was the PCM repair done by a place that specializes in repairing them?
See pic below.
Nov 11, 2022 at 1:03 PM
