No fire
253,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
COREY H JENKINS
  • 80 POSTS
Driving home (truck running like always), stopped at store, came back out and truck would not start. Towed it home
Figured out I was not getting fire. Tested cylinders one and two.
Changed out Ignition coil, distributor cap, and rotor button.
Plugs are a little dark, just put them in about six months ago and wires look good. They were changed about eighteen months ago. Checked all fuses and none were blown.
What should I be checking next to find out why no fire?
I am at a loss of what to do. Help!
Jul 26, 2017 at 8:19 AM
  • 55,710 POSTS
It sounds like the crankshaft angle sensor has gone out, here is a guide to show you what you are in for when changing the sensor.
Cheers, Ken
Jul 28, 2017 at 4:39 AM
COREY H JENKINS
  • 80 POSTS
Looking up this part online and came up with two possibilities
A crank angle sensor and a crankshaft position sensor
Which one are you talking about
Jul 28, 2017 at 5:28 AM
  • 55,710 POSTS
There are the same thing
Jul 29, 2017 at 3:49 AM
COREY H JENKINS
  • 80 POSTS
Thank you
Ordered the part on Amazon this morning
Will let y'all know if that's it
Jul 29, 2017 at 5:31 AM
