no fire
200,000 MILES • 2.3L • 4 CYL • 2WD • MANUAL
FLOPPYBUTT
The truck will crank, but it will not start. I am not getting fire to the coil packs. I have replaced the ignition control module and the computer.
May 29, 2016 at 6:15 PM
HMAC300
  • 48,601 POSTS
scan for codes first then check fuses in truck, also there are three different systems on this truck so it is helpful if you know what you have.
May 29, 2016 at 11:04 PM
FLOPPYBUTT
Thank you very much for your help. yesterday I checked the ignition control module, the coil packs, and the crankshaft piston, using the tests on your site. They let me know it is the coil packs that are bad. I am ordering them today.
Thank you
May 31, 2016 at 6:17 AM
  • 55,694 POSTS
Nice work let us know how it turns out.
May 31, 2016 at 11:23 AM
