Ticking sound, then next morning car would not start is just cranks.
Aug 5, 2016 at 4:59 PM
HMAC300
✓Experienced Mechanic
try resetting your security system on your car if no manual look online on how to do it.
Aug 5, 2016 at 10:46 PM
Hey MARK,
When the engine is cranking over does it sounds normal? the reason I am asking is because if the timing belt was starting to go out it would make a ticking noise as it falls apart, if so the cam would stop turning making the engine sounds different when it cranks over.
Please let me know.
Best, Ken
Aug 8, 2016 at 12:29 PM
MARK LUMBRERAS
MEMBER
It did make a ticking sound the night before,also it started lacking power like dragging gears.
Aug 8, 2016 at 12:33 PM
MARK LUMBRERAS
MEMBER
No spark from plugs either
Aug 8, 2016 at 12:36 PM
Can you pull off the oil cap and see if you can see the camshaft? is so have someone crank it over for you to see if the cam turns?
