Car doesnt start. If turn key it cranks but there is no spark. When you swith on there is spark at coil but when you try to crank the spark is gone. The coil is tested and in working condition. We replaced the ignition module. All wires are working. Distrubitor is fine. Battery is new. Everybody says I must replace crank angle sensor. Does this sound correct or can it be any other problem?
The car is the opel monza glx carburetor model.
Mar 23, 2016 at 5:42 PM
