no electrical power at all; battery says 12.45 volts
2000 FORD F-350
115,000 MILES • 6.8L • V10 • 4WD • AUTOMATIC
OLD PLOWER
nothing works in truck; as if battery disconnected. Has mvp western plow on it. Could this cause break in electrical system. Problem started when plow would not operate. shut truck off and now no power at all.
Dec 25, 2013 at 12:01 AM
CARADIODOC
  • 34,342 POSTS
Follow the smaller positive battery wire to the under-hood fuse box and be sure that connection is clean and tight. Follow the smaller negative wire to the body and be sure that one isn't rusty.
Dec 25, 2013 at 1:26 AM
