No electric power
178,000 MILES • 6 CYL • 2WD • AUTOMATIC
CLAMALEGUI
I just bought this used vehicle and none of the system works until we turn the key to position 2 or 3. Where should I start checking?
Mar 26, 2019 at 10:11 AM
KENW1
  • 213 POSTS
Thanks for visiting 2CarPros.
Start by checking fuse 41 in the under hood fuse box. It's a 120 amp fuse that feeds power from the battery. You can find your user manual at the link below to help with fuse identification and I'll post the wiring diagram below.
https://cdn.dealereprocess.net/cdn/servicemanuals/acura/2003-mdx.pdf
Mar 27, 2019 at 5:20 AM
