No dashboard lights, no crank no start
77,000 MILES • 4 CYL • 2WD • AUTOMATIC
KINGSLEY2019
  • 22 POSTS
The car refused to start.No crank no dashboard lights no ignition. It's a push start button.
Jun 19, 2020 at 12:29 AM
  • 110,246 POSTS
Are the other electronics on the vehicle working? For example, headlamps, windows, exterior lighting and so on.
Jun 19, 2020 at 1:39 AM
KINGSLEY2019
  • 22 POSTS
Headlight not working, windows not responding, trafficators working as well as horns.
Only door open showing on dashboard.
Jun 19, 2020 at 12:37 PM
  • 110,246 POSTS
Okay, we need to check what are called fusible links. They function the same as a fuse, but look like a regular wire.
If you look at the attached pic, I have circled five different ones. These fusible links supply power to multiple different things, so I feel this is where we need to start. Also, you indicated the horn works, and if you notice in the pic, it is a separate fuse for the horn.
What you will have to do is locate the wires by color as indicated in the pic and confirm if there is power to them.
I noted you are a mechanic, so let me know if you need anything else.
Jun 19, 2020 at 1:00 PM
KINGSLEY2019
  • 22 POSTS
Please I need help trying to locate this fusible links on the car.
Jun 20, 2020 at 6:53 AM
  • 110,246 POSTS
When you open the hood of the vehicle, they are located on the driver's side of the engine compartment in the junction box.
Jun 20, 2020 at 2:33 PM
KINGSLEY2019
  • 22 POSTS
Okay, I will check it.
Jun 21, 2020 at 2:38 AM
  • 110,246 POSTS
Let me know if I can help.
Jun 21, 2020 at 1:56 PM
KINGSLEY2019
  • 22 POSTS
I tried so hard but I couldn't locate the fusible links.
Jun 21, 2020 at 6:31 PM
KINGSLEY2019
  • 22 POSTS
There is a multiple fuse ( is it the one?);it looks good no cut.
More so when I opened the key fob.there is no electronics inside the fob.
Please what could it be?
Jun 21, 2020 at 8:39 PM
  • 110,246 POSTS
I am so sorry. I wish I could be there to help. What do you mean by multiple fuse? Also, a fusible link can look good but be bad. You need to check if power is going through it or check it for what is called continuity.
See if this link helps at all. Also, I have no idea why there are no electronics in the key fob. That makes no sense.
Jun 22, 2020 at 2:47 PM
KINGSLEY2019
  • 22 POSTS
I meant multi fuse in the fuse box not multiple fuse.
The most concern is if I can get the dashboard lights to come up,I may be able to get along from there.
Jun 24, 2020 at 12:10 AM
  • 110,246 POSTS
The power supply to the instrument panel is supplied through a 10 amp fuse in the passenger compartment (under dash/left side). Check that fuse and make sure it has power to it as well.
See pic 1.
Jun 24, 2020 at 2:50 PM
KINGSLEY2019
  • 22 POSTS
That 10 amp fuse has power on it yet the dashboard lights don't come up.
I tried to connect a piece of wire from the positive battery post to the iG1 fuse inside the car (driver's side fuse-box);then (1) the dashboard lights came up inclusive of the check engine light (2)with test light connected to negative battery post all the fuses in the EMS box (engine side fuse-box) light up .But when I disconnected the wire (which I connected to the battery positive) no light come up to the dashboard and no fuse lights up in the EMS box (engine side fuse-box).
Can the fuse-box inside the car (driver's side) be the problem area? Do I have to replace it so that dashboard lights come up normally?
Jun 25, 2020 at 12:03 AM
KINGSLEY2019
  • 22 POSTS
Help please.
Jun 25, 2020 at 12:06 AM
  • 110,246 POSTS
The ignition 1 (IG1) Is a fusible link in the underhood fuse box. It sends power to the ignition switch. Where did you connect power in the vehicle? You have me a bit lost.
What ever you sent power to is where the problem is. There is an open circuit to the fuse you powered.
Jun 25, 2020 at 1:50 PM
KINGSLEY2019
  • 22 POSTS
Okay, thank you so much.
Jun 30, 2020 at 6:14 PM
  • 110,246 POSTS
You are very welcome. If possible, could you let me know the outcome?
Jul 1, 2020 at 2:25 PM
KINGSLEY2019
  • 22 POSTS
The inside car fuse box was replaced and another key was bought and that solved the issue.
Thank you so much.
Jul 3, 2020 at 4:09 PM
  • 110,246 POSTS
You are very welcome, and thanks for letting me know. I'm glad to hear you got it taken care of. Please feel free to come back in the future if you need help with anything.
Jul 3, 2020 at 4:23 PM
KINGSLEY2019
  • 22 POSTS
There is this 2011 Sonata that after inputting the pin code keep displaying: wrong pin code .I am trying to program the key .
Please someone help me generate right pin code.i appreciate your efforts
VIN: 5NPEC4ACXBH045675
Please.
Jul 19, 2020 at 8:04 PM
  • 110,246 POSTS
I need to ask you to start a new thread for this question. We are trying to keep the posts specific to one topic. I hope you understand.
Jul 20, 2020 at 7:20 AM
KINGSLEY2019
  • 22 POSTS
Okay.
Jul 20, 2020 at 3:50 PM
