No dash lights no power with key on
2004 PONTIAC SUNFIRE
127,000 MILES
LNW
Car ran fine had a hard time getting ignitin to turn. Was told it w as ignition switch. Replaced and dash lights came on with no key. Stayed on unless I pushed the brake pedal. Un hooked battery. Lights went out but will not come back on and car will not crank. Only light on is the a/c
Jan 3, 2016 at 3:29 AM
LNW
Also checked all fuse under the hood, all are good. When I turn car on it makes some noise behind the instrument cluster
Jan 3, 2016 at 3:32 AM
HMAC300
  • 48,601 POSTS
try resetting your anti theft unit this may be the correct way in pic if not have it scanned for codes.
Jan 3, 2016 at 11:58 PM
