no cruise control srs light on
195,892 MILES • 1.7L • 4 CYL • 2WD • AUTOMATIC
SHOPRAT123
srs light came on a few days ago then the cruise control quit working. I have checked the fuses} switch for continuity no power to the black cruise control box.
Jun 19, 2014 at 8:38 AM
CARADIODOC
  • 34,416 POSTS
Suspect a broken clock spring. That's a wound-up ribbon cable in a plastic housing under the steering wheel. Most likely your horn doesn't work either.
Jun 19, 2014 at 2:50 PM
