No crank when warm
88,000 MILES • 1.6L • 4 CYL • FWD • AUTOMATIC
RICHARD SCHELLHARDT
TCM replace three weeks ago, also reprogram PCM by Ford dealer. Car has power but will not crank when warm. Drove it ten miles turned it off. No crank when I returned thirty minutes later. Let sit thirty minutes cool of time and it cranks no problem. The same trip average mpg on dash was twenty six mpg. Return trip of ten miles and average mpg jumped to thirty one mpg. Not sure if it is related. Throttle body, o2 sensor replaced 1,500 miles ago.
Jan 24, 2017 at 10:20 AM
HMAC300
  • 48,601 POSTS
make sure battery is in good condition including load test most places do for free. also, make sure terminal ends are clean. then when it does it again there is a module under passenger seat tap with a screwdriver and see if it starts. if it does then it needs replacing. also a mechanic will have to scan for codes to verify. if this does not work then it will have to be scanned for codes by a mechanic. also, check starter relay under hood for corrosion on prongs if any try to clean and use dielectric grease on them.
Jan 24, 2017 at 11:34 PM
RICHARD SCHELLHARDT
Thank you, will try those things first.
Jan 25, 2017 at 3:09 AM
RICHARD SCHELLHARDT
I have cleaned the ground connection and checked the relays contacts. The ecm is not under the seat but behind the splash shield on the drivers side. I switched the relays, only time will as this is an intermittent problem. Thanks for the help, Richard
Jan 26, 2017 at 10:10 PM
  • 55,721 POSTS
Hey RICHARD,
I have seen where the the starter motor is going bad when it gets hot it doesn't work and then when it colds down it works again, just me two cents.
Let us know what happens so ti will helps others.
Best, Ken
Jan 30, 2017 at 8:55 PM
RICHARD SCHELLHARDT
Thanks for the input, I have swapped relays in the fusebox with one not so important(reverse lights) and all is well so far. If no problems arise in the next week or so I will buy a new relay and install it in the starter position and put the borrowed one back in the correct place. Thanks again for the responses.
Jan 30, 2017 at 9:52 PM
  • 55,721 POSTS
No problem please use 2CarPros anytime we are here to help.
Jan 30, 2017 at 11:53 PM
