No crank when hot
2005 KIA SEDONA
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
MISSTYLER TYLER
Starts great after sitting for a few hours. Drive it a while, turn it off and try to start it within an hour or two and no crank/no start- nada. Hear one click each attempt to start. Will not jump start, have lights/radio etc. Battery and connections are in great shape.
Aug 17, 2018 at 10:20 AM
  • 110,244 POSTS
If you hear a click either one of the connections are corroded or loose, or the starter itself is going bad. Take a look through this link and see if it sounds like the same issue.
If it does not, I have to be honest. It sounds like the starter is going bad. When they get hot, things expand inside and they can fail. I would like to say remove the starter and have it bench tested at a parts store, but it will be cold then and work.
If you decide to remove it and have it tested, here are general directions for removing a starter:
Aug 17, 2018 at 1:33 PM
