No crank, no start when warm?
150,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
RFINGER374
The vehicle starts fine when the engine is not hot. When the engine gets hot, the starter will not crank, and I hear a slow ticking. If I open the hood and wait 20 - 30 minutes, the car starts right up. I changed the battery and the starter with no change.
Aug 21, 2023 at 7:14 AM
  • 110,248 POSTS
That is an interesting one. If a new battery and starter changed nothing, it could be a few things.
First, I attached the wiring schematic for the starter circuit below so that you have a reference. Before I jump into that, I have a question. When you hear the slow clicking, is it coming from the starter motor?
Also, I noticed in the schematic there is a connector between the power module and the starter motor trigger post. I need you to check the condition of that connector. Disconnect it and check the connector pins to make sure they aren't corroded or damaged. Pic 3 below shows the connector location.
Aug 21, 2023 at 1:14 PM
RFINGER374
Thanks for the info. I can tell you the connector on the starter side was clean. I can take a look at the TIPM side tomorrow. Can you help with the location of the connector in the middle? It appears buried in wire loom.
Aug 23, 2023 at 7:07 AM
  • 110,248 POSTS
No problem. The relay output is in connector 10 and is pin 8. If you look below, I attached two pics. The first shows the connector pinout and the color of the connector. It is an 8-pin, light gray connector. I highlighted the connector pin.
The second pic is a legend of the connector pins.
Let me know if this helps.
joe
Aug 23, 2023 at 12:59 PM
