no crank/no start nightmare
159,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
BFRAZER
  • 7 POSTS
just bought truck so i do not know much about the history. when i bought it , it had a blown head gasket. i had it towed to my house. i replaced both head gaskets and all the rest of the gaskets above the heads. got everything put back together, turn the key, and does not even get a click. i checked for power at the #30, #87, #85 terminals of my starter relay. i have 12 volts at these terminals. what i do not have is 12 volts in the start position, when i jump the #85, and #86 terminals of my starter relay. i took the cover off off the relay, and when its plugged in, i can close the contacts manually, and the engine will crank over. i can even get it to run if i prime it first. i checked for 12 volts at the crank fuse, okay. i checked for 12 volts at the purple wire at the park/neutral switch in the start position, okay. i manually jumped the purple to the purple with white stripe wires at the park/neutral switch, nothing happens. i checked for continuity on the purple with white stripe wire from the park/neutral switch to the #87 terminal on the starter relay, okay. that is where i am at now. what do i check next ? should the #86 terminal be a ground? i believe it is opened. i saw a step by step method on here for checking the circuit. i did that and it brought me to where i am now, lost.
Sep 2, 2016 at 5:39 AM
WRENCHTECH
  • 20,758 POSTS
Check for a missing ground on the back of the right cylinder head.
Sep 2, 2016 at 6:07 AM
BFRAZER
  • 7 POSTS
i did that, that was my number one suspect. i have checked that more than once to make sure i have a solid ground. i am thinking i need to check the #86 terminal wire on my relay to wherever it goes for continuity.
Sep 2, 2016 at 6:52 AM
WRENCHTECH
  • 20,758 POSTS
Pin 86 goes directly to that ground on the engine.
Sep 2, 2016 at 6:56 AM
BFRAZER
  • 7 POSTS
so that black wire that grounds to the back of the head on the right side is a direct connection to #86 of my starter relay? i was thinking that the #86 terminal turned into a yellow/black wire and it ran to the #76 terminal of the PCM? i am going to go put hands on my truck and do a continuity test from #86 to both.
Sep 2, 2016 at 7:12 AM
BFRAZER
  • 7 POSTS
does anyone have a good detailed schematic for my trucks starting circuit they can send me?
Sep 2, 2016 at 7:13 AM
WRENCHTECH
  • 20,758 POSTS
Yes, that is what I said. https://www.2carpros.com/images/external/85086884.gif
Sep 2, 2016 at 7:14 AM
BFRAZER
  • 7 POSTS
okay, i am 100% sure that my ground wire is good. i have 12 volts on the #30 terminal in the start position, i have 12 volts on the #87 terminal, but i am only getting .374 volts on the #85 terminal in the stasrt position. that is the starter relay terminals in the distribution box. Help!
Sep 2, 2016 at 10:38 AM
BFRAZER
  • 7 POSTS
okay, so the #85 terminal goes from the relay, to the park/neutral switch through the purple with white stripe wire. i checked the continuity on that wire and it is good, (.000). i tried jumping the purple with white stripe wire to the purple wire down at the park/neutral switch. nothing happens. i do have 12 volts at that plug on the purple wire in the start position.
Sep 2, 2016 at 10:42 AM
WRENCHTECH
  • 20,758 POSTS
That only powers in the "start" position. It comes from the neutral safety switch.
Check the 10 amp crank fuse in the under-hood fuse box.
Sep 2, 2016 at 10:43 AM
BFRAZER
  • 7 POSTS
so, everything is kind of pointing towards the park/neutral switch? i do have 12 volts at the crank fuse also.
Sep 2, 2016 at 10:45 AM
WRENCHTECH
  • 20,758 POSTS
If you have power at the Purple with white wire, then you should have it at the relay also. If not, the fuse box could have a problem.
Sep 2, 2016 at 10:46 AM
