security disable
200,000 MILES • 3.8L • V6 • TURBO • 2WD • AUTOMATIC
WESLEYBUTLER
  • 10 POSTS
GS model supercharged: Solid security light and solid check engine light lit for over a year with the engine running fine before scanning. I scanned all systems with Blue Driver OBD2 Diagnostic Scan Tool while the engine was running. Scan revealed confirmed codes P0102 and B2958. It also displayed historical security codes B2960, B2957 and B2961. I selected "clear all codes" and then the engine shut off. I attempted to restart the vehicle but the vehicle only clicked, no crank, no start. I attempted the GM Passlock relearn procedure but it did not work. No crank, no start and the solid security light, check engine light still remain. I scanned the system again and current security code B2958 and historical security code B2960 are the only codes that remain. Battery is fully charged. Can a scan tool really cause a vehicle not to start? How do I fix this?
Feb 12, 2018 at 3:39 PM
Good morning.
The click that you hear, is it coming from the starter motor?
Make sure your battery connections are clean and tight.
Do you have a voltmeter to check the voltage at the battery?
No, not usually, the check engine light should not affect the starting when cleared.
Feb 12, 2018 at 5:36 PM
WESLEYBUTLER
  • 10 POSTS
With the key in the "on" position, I can hear the fuel pump priming. When I turn the key forward to crank, I hear a relay in the dash click one time. Battery connections are clean and tight. I charged and load tested the battery. It is around 12.5 volts sitting and 14 volts when charging. The car literally went from running to not running right in front of my eyes and the only action I had taken before hand was running a scan tool and clearing codes.
Feb 13, 2018 at 3:29 AM
Okay, thanks.
Does the theft light stay on with the key on or does it go off after about ten seconds?
Feb 13, 2018 at 3:33 AM
WESLEYBUTLER
  • 10 POSTS
"No crank, no start and the solid security light, check engine light still remain." The theft light stays on solid (not blinking) with the key on.
Feb 13, 2018 at 3:45 AM
Try the password relearn.
Turn the key to on. let it set for ten minutes, the light should go out.
Then turn the key off and back on again and wait for ten minutes.
Turn the key off and on again and wait ten minutes until the light goes out. That is when the key learns the password and see if it will start.
Feb 13, 2018 at 3:57 AM
WESLEYBUTLER
  • 10 POSTS
"I attempted the GM Passlock relearn procedure but it did not work." This procedure is exactly what you have instructed to do. I performed the full procedure. Even though most instructions state that the security light will be blinking beforehand, mine was solid. The procedure states the light will go out after the first ten minutes. Mine is still on solid after the full thirty minute procedure.
Feb 13, 2018 at 4:03 AM
Okay, then there is a fault in the security system that will not allow the key to learn the password.
Let me check on that system.
Feb 13, 2018 at 4:20 AM
There is also a thirty minute relearn procedure as well. it is posted below.
Thirty Minute Learn Procedure:
1. Turn "on" the ignition, with the engine "off".
2. Attempt to start the engine, then release the key to "on" (vehicle will not start).
3. Observe the security telltale, after approximately ten minutes the telltale will turn off.
4. Turn off the ignition, and wait five seconds.
5. Repeat steps one through four two more times for a total of three cycles/thirty minutes (the vehicle is now ready to relearn the password on the next ignition switch transition from off to crank).
Important: The vehicle learns the password on the next ignition switch transition from off to crank. You must turn the ignition off before attempting to start the vehicle.
6. Start the engine (the vehicle has now learned the password).
7. With a scan tool, clear any DTCs if needed (history DTCs will self clear after 100 ignition cycles).
Feb 13, 2018 at 5:09 AM
WESLEYBUTLER
  • 10 POSTS
If you look closely that is the same procedure.
Feb 13, 2018 at 8:16 AM
Yes, with the exception of turning the engine to the start position. It is different. give it a try before we start talking more about the theft deterrent system.
Feb 13, 2018 at 4:32 PM
WESLEYBUTLER
  • 10 POSTS
SOLVED: I removed the radio/HVAC bezel and steering column top/bottom covers to gain access to the ignition cylinder. One of the small white wires on the ignition switch that sends the resistance value from the key pellet to the GM Passkey system was broken. Before fixing anything, I attempted to start the car and it started right up with wire broken and the security light lit. I soldered the wire together. Car now starts and runs fine with no Security light and no current security codes. I'm still not sure what the cause of the original no start issue was. It truly seemed like the engine dying and not restarting correlated with clearing the security codes. Obviously the wire damage was a long standing issue that needed to be corrected. Anyways, thank you for your input. It is truly appreciated.
Feb 19, 2018 at 2:16 PM
  • 55,688 POSTS
Great find I though GM fixed this problem on the older cars but I guess not this thread will help many nice work ;)
Cheers, Ken
Feb 22, 2018 at 4:34 AM
