No crank, no start
150,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
BURK MCDUFF
I drove car about 20 miles, then parked it in my driveway. After 5-10 minutes, i attempted to start car again. no crank, no start, no dashboard lights, nothing! Lifted hood, and while "looking around" heard a slightly loud "click" sound. do not know where it came from. ? Attempted to start car again and it started this time. Since i'm crippled, i'm afraid of getting stranded if this happens again in future. Do you have any suggestion about a faulty, sticking, switch or sensor that could be causing this? Many thanks from my "anxiety switch"..
Burk McDuff
Feb 27, 2021 at 4:49 AM
  • 110,251 POSTS
Since the starter wouldn't engage, the first thing that comes to mind is the starter relay. They do make a clicking sound when actuated.
Under the hood on the driver's side of the vehicle is the fuse/relay box. The starter relay is located there. I attached a picture to help you locate it.
I can't guarantee this is the problem, but since it started after hearing a click, it leads me to believe it is.
If you want, here is a link that shows how to test a relay:
Take care and God Bless,
Feb 27, 2021 at 12:45 PM
BURK MCDUFF
Very logical ! Since i'm a bit handicapped, my day starts slowly. Later today, i'll check-out your advice.. then will reply back to you. Thanks again !!!
Mar 1, 2021 at 5:06 AM
  • 110,251 POSTS
You are very welcome. Let me know if you have other questions and what you find.
Mar 1, 2021 at 8:37 AM
