No crank, no start
150,000 MILES • 4.7L • V8 • 2WD • AUTOMATIC
JULIANALANIS19
Edit: The truck is a 2004. I get in the truck, then i put the key in all lights come on. When i turn the key over to start the car. It makes one click sound and the car shuts off. If you could answer this as soon as possible, it would help a lot. Note: We have already tried to clean the battery connectors and there is a new battery.
Feb 6, 2020 at 5:16 AM
CARADIODOC
  • 34,414 POSTS
Follow the smaller battery positive wire to the under-hood fuse box and be sure that connection is clean and tight. That's a common source of this symptom on all car brands.
Also follow the smaller battery negative wire to the body and be sure that connection is tight and not rusty.
Feb 6, 2020 at 7:26 AM
