No crank, no start
152,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
YOUNGB3E
Car started before putting it into garage to get worked on. Couple weeks, it sat. Replaced transmission solenoid. Put everything back in and now the car doesn’t start or cranks. Help?
Jan 25, 2021 at 4:33 AM
  • 110,248 POSTS
I'm not sure which solenoid was replaced, but my first suspect is the shift linkage is off or the range sensor is disconnected.
First, here is a link you may find helpful:
Next, let me know if the shift indicator is accurate and if it will start in neutral.
Jan 25, 2021 at 11:40 AM
