No crank no start?
172,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
BOSTONJ93
Power to some of the fuses in box. Car won't start.
Aug 16, 2023 at 8:47 AM
  • 110,251 POSTS
I'm not sure which fuses you are referring to and which fuse box. Please advise.
Since the starter isn't engaging, I attached the starter wiring schematic below, so you have a reference. I highlighted primary wiring. The first thing I need to know is if 19 in the battery junction box (under the hood) is good and has power to and from it.
Also, here is a link you may find helpful:
Note: Pics 1 and 2 below are from one page. I had to cut it in half to make it readable for you. I did overlap them so you can follow from one to the next. Additionally. pic 3 shows the fuse location (fuse 19)
Let me know what you find.
Aug 16, 2023 at 3:31 PM
