Why does the engine not crank or start?
105,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
ROBERT J. BEEMAN JR.
I have replaced the following:
Starter
Alternator
Pullies
Tensioner
A/C compressor
Fuse box under the hood
Relays
Fuses
When I turn the key over everything comes on. No codes are being offered in the diagnosis. However, when pushed into the start position my dashboard goes blank. I don't want to have to replace the ignition if I don't have to. Also, curious if this is a case of needing to reprogram the keys, which would make super happy. That seems to be an easy process.
Also, the local pick and pull has an ignition that has all of the keys with it. The man that run the place said if I pulled the Body Control Module with it, I wouldn't have to do any reprograming at the dealership. Does that sound right?
Aug 11, 2022 at 10:02 AM
  • 55,691 POSTS
Do you have a security light flashing when you try to crank it over? If not, it sounds like the dash integration module (BCM) is not working. Here is the location of the module so you can check it out and replace it. Here is the location and how to replace it in the diagrams below. Check out the diagrams (below). Let us know what happens and please upload pictures or videos of the problem.
Aug 12, 2022 at 1:11 AM
As a matter of a fact the dash does go black when attempting to start. I have misplaced my fob and tried to use the valet key to start it.
Aug 12, 2022 at 1:15 AM
  • 55,691 POSTS
Okay. We need to load test the battery or you may have a bad connection at the battery. These guides can help us see which problem you have; the battery test does not require equipment.
and
Aug 12, 2022 at 4:44 AM
Okay, so, the lights do not dim. I think it’s the security system. I have misplaced the fob and master key. All I have is my valet key. When I turn the valet key over the dash goes black.
Aug 22, 2022 at 10:03 AM
  • 55,691 POSTS
Okay, it sounds like a bad connection at the battery.
This guide can help you fix it:
Do all of the lights go you when you turn the key?
Aug 23, 2022 at 5:01 AM
