it makes a clicking sound coming from the center console
184,000 MILES • 1.9L • 4 CYL • 2WD • AUTOMATIC
CONRADISH006
  • 53 POSTS
I am fixing this car for a friend. And the battery had died so I tried to jump it and it would not receive a jump. So I tested the battery and it failed. So I replaced it. And that battery was dead. So I tried to jump it and the battery charged. But cranked twice and that was it. And whenever I climb in it makes a clicking sound coming from the center console. And the battery strangely dies. Even when it has not ran?
Feb 5, 2019 at 9:58 AM
SCGRANTURISMO
  • 4,897 POSTS
This sounds like a parasitic draw issue. Here is a helpful link that should help you run down the problem. Let us know what you find out.
https://www.2carpros.com/articles/car-battery-dead-overnight
Alex,
2CarPros
Apr 20, 2021 at 4:20 AM
CONRADISH006
  • 53 POSTS
I am going to test the ignition switch and the neutral safety switch. Could those be the problem?
CONRADISH006
  • 53 POSTS
Would the clicking be the neutral safety switch?
SCGRANTURISMO
  • 4,897 POSTS
Have you had the second battery load tested? The clicking you hear could be the starter not receiving enough amps to turn the engine.
SCGRANTURISMO
  • 4,897 POSTS
You can usually have a battery load tested free of charge at your local parts store.
RENEE L
  • 1,260 POSTS
Hi CONRADISH006,
If you decide to check the condition of your battery yourself here is a link to helpful information from this site that features written instructions, pictures and a video explaining how to load test your battery yourself. If you need further assistance please come back to 2CarPros.com. We are always happy to help.
Thank you for visiting 2CarPros.
Kindest regards,
Renee
Admin
CONRADISH006
  • 53 POSTS
My friend took it to a mechanic . And he said that the valve cover gasket had blown and sent oil onto the spark plugs and wires. Causing a battey drain.
  • 55,808 POSTS
That does not make sense, can you ask him how spark plugs and oil can drain the battery?
CONRADISH006
  • 53 POSTS
I have no contact with this mechanic. He said that a rodent had chewed through the gasket. I am thinking this guy is lying.
Apr 20, 2021 at 4:21 AM
  • 55,808 POSTS
It happens. here is a guide to help you check the wiring to the starter and the wiring diagrams so you can see how the system works:
Check out the diagrams (below). Please run this test and get back to us.
CONRADISH006
  • 53 POSTS
CONRADISH006
  • 53 POSTS
It has a generator instead of an alternator.
CONRADISH006
  • 53 POSTS
Fortunately I have Alldata through my library.
