no crank no start?
185,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
MK7CASEY
  • 17 POSTS
I have the car listed above SS model.
I have had a no crank no start, not turning on or starting no audible click with starter either. Just put a brand-new starter in the car and I am still experiencing the same exact issue.
Nov 16, 2021 at 11:10 PM
Good morning,
I attached a wiring diagram for you to view.
You need to test for any power to the starter solenoid with the key in the start position.
This could be a bad starter, relay, or park/neutral switch.
Nov 17, 2021 at 12:00 AM
MK7CASEY
  • 17 POSTS
I am guessing I will use a test light to test the purple wire at the starter for power then?
Nov 17, 2021 at 12:56 AM
That will be fine. It should have power only in the start position.
Nov 17, 2021 at 12:58 AM
MK7CASEY
  • 17 POSTS
Okay, as soon as I get home I will start testing. also not sure if this rules out the Neutral Safety Switch but the car doesn't start in neutral either.
Nov 17, 2021 at 1:04 AM
Check and see if the backup lights work. If they work, then you may be correct.
Nov 17, 2021 at 1:05 AM
MK7CASEY
  • 17 POSTS
Ignition to on position and I’m not getting power from the purple wire.
Nov 17, 2021 at 7:30 AM
As I stated, the key needs to be in the start position, not the on position.
Try it that way and let me know.
Nov 17, 2021 at 7:32 AM
MK7CASEY
  • 17 POSTS
found the issue was my starter relay, I took it out adjusted the pins and the car starts every time now.
Nov 22, 2021 at 9:56 PM
Good find.
Glad to hear it works.
Nov 22, 2021 at 9:57 PM
