No crank no start?
171,000 MILES • 5.2L • V8 • 2WD • AUTOMATIC
T&JHOOPER
  • 8 POSTS
We have the truck listed above 1500. I just replaced the starter, flex plate, torque converter and neutral safety switch. The truck was cranking when we tried bypassing the starter relay but now it won't. All outside lights work. dash and radio and A/C come on, but it won't crank. Starter and battery both show 12v. Don't have a clue what's going on.
Sep 11, 2023 at 11:40 PM
  • 55,770 POSTS
If you are getting 12 volts at the trigger wire for the starter and the battery cables are clean and tight it sounds like you have a defective starter. But to be sure let's use this guide and I have included the starter wiring diagrams and a guide to help you check for power to see where you lose it.
and
Check out the images (below). Please let us know how it goes.
Sep 12, 2023 at 5:19 AM
T&JHOOPER
  • 8 POSTS
Thank you very much, I will definitely let you know.
Sep 12, 2023 at 6:28 AM
T&JHOOPER
  • 8 POSTS
My husband tried to hot wire it at the steering column but still no crank no start and not throwing codes.
Sep 12, 2023 at 6:12 PM
  • 55,770 POSTS
Do you have power at the trigger wire of the starter while in the crank position? Please check out the wiring diagrams above.
Sep 13, 2023 at 4:13 AM
T&JHOOPER
  • 8 POSTS
The trigger wire read 0.04.
Sep 13, 2023 at 7:33 AM
T&JHOOPER
  • 8 POSTS
Found the problem, it was a wire broke off inside of the starter.
Sep 13, 2023 at 10:08 AM
  • 55,770 POSTS
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
Sep 14, 2023 at 4:00 AM
T&JHOOPER
  • 8 POSTS
Lol it's definitely not fixed yet. I'm hoping that's what the whole problem is and there's not more problems after this.
Sep 14, 2023 at 4:22 AM
T&JHOOPER
  • 8 POSTS
Now we have it cranking under the hood but it won't crank at the ignition...could it be a bad ignition switch or coil?
Sep 16, 2023 at 3:31 AM
  • 55,770 POSTS
It could be a bad ignition switch, did you run the test I outlined in the previous post? Use the test light to see where you are losing power. Test through the ignition switch.
Sep 18, 2023 at 3:50 AM
T&JHOOPER
  • 8 POSTS
I don't have a light, I just have a multimeter, but I'll do my best to go over the diagram. i'll start at the ignition switch.
Sep 18, 2023 at 4:44 AM
  • 55,770 POSTS
Sounds good please let me know.
Sep 20, 2023 at 1:52 AM
