I was testing the Tps when I touched the hot wire it grounded out or something. Now car wont crank. Starter, battery, ignition, clutch safety switch. All test good. I think it is down to three things. Pats transponder, pats system or ECM. When I turn the key auxiliary fan comes on ABS lights come on, but no check engine light. I get a single click at the PCM relay. I have put another relay in it. I have hit a wall on this one and need help.
Jul 27, 2016 at 10:09 PM
