No crank no start?
115,530 MILES • 4WD • AUTOMATIC
DENETRISHATCHER
After driving all day doing birthday party errands, I came out of the last store and my jeep wouldn’t start. I wasn’t having any issues leading up to the issue. The first three attempts to start the vehicle it cranked started and slowly shut off within about two seconds. The second two attempts the jeep only cranked but would not start. The last few attempts. The vehicle would not crank nor start. I had one mechanic who told me it was definitely the starter only until later told me he wasn’t sure, so I purchased a starter, climbed under my vehicle and replaced the starter myself. My vehicle does not start, still no crank either. My battery voltage is 12.2 and when the mechanic was attempting to start the vehicle somehow, he got it to crank, and we heard a noise that just sounded like the engine was struggling. I don’t know how to explain the sound and there was a small bit of white smoke that came from underneath the vehicle in the front.
The mechanic says that it’s my engine, no machines were attached to the car and that is a $3,000 repair. I don’t know if it’s something that is connected to the engine or if it’s the engine itself but if I can save myself a $3,000 repair, I would love that I just need help figuring out what it could be. When the key is turned, the lights all come on, and the radio works the key, remote unlocks and locks the doors as well as turns on and off the alarm.
Jul 24, 2023 at 11:24 AM
DENETRISHATCHER
Okay, so I guess I should include when I turn the key, I hear a whining noise from the engine.
Jul 25, 2023 at 2:27 AM
AL514
  • 5,700 POSTS
You should try to turn the engine over by hand, putting a socket and bar on the crankshaft pulley bolt, it sounds like the mechanic might have jumped power over right at the Starter motor. If you can't turn the engine over by hand, you can remove the spark plugs so you're not pushing against the compression of the engine. If you hear mechanical noises that do not sound right, or if you still can't turn it over, something is locked up.
You can drain the oil and check it for any metal particles in it or in the oil filter. It's difficult to say exactly what happened. But if it won't turn over easily by hand with the spark plugs out, it can be any number of things that might have seized up. You can also try pulling the main drive belt off and try it that way. Seeing if something driven by the belt has seized up. There are a couple guides here to help.
If you take out the spark plugs and it happens to turn over, watch for any liquids coming out of the spark plug holes. If for some reason a fuel injector completely flooded a cylinder, it may have hydro locked. So, I wouldn't try turning it over with the key until you see if it will turn by hand, you don't want to damage anything else.
https://www.2carpros.com/articles/chirping-noise
https://www.2carpros.com/articles/comprehensive-guide-to-identify-and-fix-ticking-and-tapping-noises-in-engines
Jul 25, 2023 at 7:22 AM
