No crank no start no instrument lights coming on?
3.6L • AUTOMATIC
REDBONE
  • 108 POSTS
when i turn the key on i have no instrument lights coming on and when i try to start it doesn't crank. checked all the fuse, battery fully charged. I even tried to bypass crank relay and it didn't crank. What could cause this.
Nov 24, 2026 at 3:32 PM
  • 55,865 POSTS
Hello, It can be a bad battery still, did you have it load tested? If you are sharing a bad battery it will not help. Also, it can be the battery terminals. Do you have after market terminals? If so please unload an image of them so I can see what is going on. Here is a guide and video that can help.
https://www.youtube.com/watch?v=6YRW8fyNudY&t
and
https://2carpros.com/articles/everything-goes-dead-when-engine-is-cranked/
Nov 25, 2026 at 12:09 PM
REDBONE
  • 108 POSTS
Battery is new, terminals clean i turn the key to on instrument lights flicker and doesn.t stay on, have radio, headlights but no crank, even tried unhooking negative cable from battery and hooking jumper from neg cable to pos cable to drain system, get power to fuse box but won.t start security light flashes rapid that is why i did the jumper wire but didn't work, could the module that goes around the ignition be bad, seems like it is in anti theft mode.
Nov 28, 2026 at 5:41 AM
  • 55,865 POSTS
Yep, this might be the instrument cluster has gone bad but we need to do a CAN scan to see which codes come up.
https://www.youtube.com/watch?v=InIlnsjOVFA&t
Let me know what happens.
Nov 28, 2026 at 8:37 AM
REDBONE
  • 108 POSTS
I did a code scan and had a history code B3055, i did the 30 min. relearn and still no start.
Nov 29, 2026 at 10:52 AM
  • 55,865 POSTS
So when you say "no start" do you mean no cranking over (starter) or the engine cranks but will not run?
Diagnostic trouble code B3055 means "No Transponder Modulation" or "No Transponder". It occurs when your vehicle's immobilizer system (often part of the Body Control Module or Theft Deterrent Module) cannot read the RFID transponder chip inside your ignition key, which can prevent the engine from cranking or starting
So when you try to start the engine is the security light flashing?
Nov 29, 2026 at 6:00 PM
