No crank starter does not engage?
150,000 MILES • TURBO • 4WD • AUTOMATIC
WICKEDGHOST 74
I’m having issues with this srx4 starter does not engage or turn with either key I’ve tested all fuses and relays with know good ones the only way the starter engages is with jumping pins 30-87 however it dose not turn only engaging the bendix gonna try a bilateral scan tool but I need sum help on this please
Oct 26, 2026 at 3:55 AM
  • 110,251 POSTS
Have you replaced the relay? That is what sounds faulty. If you jump pins 30 and 87 and the starter engages, the only other thing would be if pins 85 and 86 either get no power or no ground to actuate the relay, or the relay is bad.
Take a look at this link for testing a relay. See if it helps and let me know.
https://2carpros.com/articles/how-to-check-an-electrical-relay-and-wiring-control-circuit/
Also, if the bendix is the only thing that engages and the starter doesn't turn the engine, make sure you have a good connection between the battery and starter. If you do, chances are the starter itself is faulty.
If I misunderstood what you are experiencing, let me know.
Oct 26, 2026 at 6:22 PM
