No crank no start
2005 DODGE 600
215,000 MILES • 3.3L • V6 • 2WD • AUTOMATIC
MAUD05
  • 6 POSTS
Deep freeze have not started it in a month. Tried to start it it would not start. defrosted the battery tried jumping it. nothing can hear fuel pump and a clunk on the engine.
Jan 15, 2017 at 11:20 PM
HMAC300
  • 48,601 POSTS
try a security system reset. See link.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Jan 16, 2017 at 1:28 AM
JOHNNY G.JR
  • 320 POSTS
Charge battery carefully and slowly overnight and have it load tested at auto parts store,usually a free service. A frozen battery is a sign of one that was undercharged or in a very weak condition,more than likely needs to be replaced. Jump starting a frozen battery could have been fatal!!!
Jan 16, 2017 at 5:46 AM
JOHNNY G.JR
  • 320 POSTS
Remove plugs and try to turn engine over by hand with a socket wrench on crankshaft pulley,reply back with results.
Jan 16, 2017 at 5:49 AM
MAUD05
  • 6 POSTS
It is charged. also, it is a lease with GPS. Checked all fuses and relays. Trying the reset thing from the link that was sent.
Jan 16, 2017 at 10:06 AM
MAUD05
  • 6 POSTS
Also, there is a buzzing sound from the dashboard when it is in on position. Everything shuts off when it is turned to start.
Jan 16, 2017 at 10:19 AM
HMAC300
  • 48,601 POSTS
have you tested the battery, not its charged? sure sounds like a battery problem or dirty terminal ends on battery.
Jan 16, 2017 at 9:42 PM
MAUD05
  • 6 POSTS
It has not ever given me a problem for starting . I will get the battery tested. I am sure there is a security problem. why I cannot get a turnover cause I tried my battery on it as well. It is my wife's van.
Jan 16, 2017 at 10:28 PM
MAUD05
  • 6 POSTS
The battery is ok and it can be turned with a ratchet. Still stuck asked the dealership said it is not on a shutdown. Any thoughts , also no power to fuel pump or starter the relays in the fuse box click are accessory and fan
Jan 18, 2017 at 10:38 AM
HMAC300
  • 48,601 POSTS
it sure sounds like a security problem. scan for codes it may be a tpim module
Jan 18, 2017 at 10:14 PM
MAUD05
  • 6 POSTS
Is ob2 an adequate scanner
Jan 18, 2017 at 11:04 PM
HMAC300
  • 48,601 POSTS
OBD2 is the system you need a scanner that will work on that. However a scanner at an auto parts will not read a tpim module problem a mechanic with a professional scanner can
Jan 18, 2017 at 11:28 PM
