No crank, no start?
120,000 MILES • 3.5L • 5 CYL • 4WD • AUTOMATIC
LFIORE
  • 6 POSTS
pulled into driveway placed into park ran inside, returned to vehicle turned key nothing, no crank, I can hear fuel pump turn in, I can hear relays click. I tested the starter solenoid, no power, I assumed it was the security bypass, but the light did not blink. I changed the crank relay no change. checked fuses all good. What tests can I perform in sequence to troubleshoot? Thank you.
Apr 3, 2023 at 9:38 PM
  • 55,616 POSTS
There are four fuses that run the system we need to check for power also there is an additional relay as well. Here is a guide to help you test for power and the starter wiring diagrams so you can see how the system works and where to test for power and grounds. Also, I would run the codes to see what comes up, you can get a CAN scanner (Controller Area Network) from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
and
Here is one for about $99.00 if you need it:
https://amzn.to/3ZixY4v
Here is how to check for power and ground:
Apr 4, 2023 at 2:25 AM
LFIORE
  • 6 POSTS
I performed the test using a test light, had power at starter fuse30A, had power at PCM control relay pin 30 also, following diagram had power at run/crank relay also at batt ignition fuse 10A. Plugged in the Audel scanner received following code P0340 camshaft position sensor circuit, P0365 camshaft position sensor B circuit. scanner also indicated modules present SAE J1 850 VPW.
Apr 9, 2023 at 8:33 PM
  • 55,616 POSTS
So, does the engine crank over (starter working) or does the engine crank over but not run? Can you please shoot a quick video with your phone so I can hear the engine cranking over? That way I can tell for sure what's going on. You can upload it here with your response.
Apr 10, 2023 at 7:29 AM
LFIORE
  • 6 POSTS
The engine does not crank. When I turn the key to start there is no power to the starter solenoid when using the test light.
Apr 10, 2023 at 7:40 AM
  • 55,616 POSTS
Okay, do you have a security light flashing when you try to crank the engine over? If not, I would swap out the crank relays to see if that fixes it. Here are the locations #77 and #78. Check out the images (below). Please let us know what you find.
Apr 11, 2023 at 3:50 AM
LFIORE
  • 6 POSTS
no security light flashing, replaced start crank relay no change.
Apr 12, 2023 at 9:24 PM
  • 55,616 POSTS
We need to do a CAN scan.
Apr 13, 2023 at 5:11 AM
LFIORE
  • 6 POSTS
performed can scan, following results.
P0340 Camshaft position sensor A circuit
P0365 Camshaft position sensor B circuit
Modules present SAE J1 VPW
Monitors N/A 3
Monitors ok 3
Monitors INC 4
Apr 13, 2023 at 8:54 PM
  • 55,616 POSTS
I would use the starter wiring diagrams above to see where you are losing power when the key it turned to the crank position.
Please go over this guide and report back.
Apr 15, 2023 at 3:05 AM
LFIORE
  • 6 POSTS
Performed tests on starting utilizing test light, there was power to purple wire up until the connection covered with shrink tubing. When I moved the connection the test light confirmed power. I cut and removed shrink wrap cover and found corrosion and looks like a previous repair done poorly. I stripped wire and soldered connection. Started right up.
Thank you for the guidance.
Apr 30, 2023 at 12:23 AM
  • 55,616 POSTS
Thanks for letting us know, we are here to help, please use 2CarPros anytime.
Apr 30, 2023 at 3:52 AM
