No crank no start
110,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
KELSEY CLARK
  • 10 POSTS
I replaced the upper ignition actuator because the pin broke. I got it changed out put it all back and no crank no start. Everything is working normal. New ignition switch, new starter relay new ignition cylinder. Have taken it apart twice to make sure no pinched wires and connectors together right. I can jump it at the start relay and starts and runs good. Had it tested for codes and B1600 came up. I also have a clip (I think it is) and do not know where it came from. I need help please.
Feb 27, 2018 at 12:17 PM
  • 55,748 POSTS
You have a security issue with your car. is the light blinking when you try and start the car?
Are you using the same key?
Here is a guide to help you reset the system:
https://www.2carpros.com/articles/how-to-reset-a-security-system
Cheers, Ken
Mar 1, 2018 at 7:36 AM
KELSEY CLARK
  • 10 POSTS
I have tried all five steps to reset the anti-theft and still will not start. When I start the car the theft light comes on then it shuts off after a few seconds. The accessory delay relay clicks every time I turn it to start. Yes, I have been using the same key. I am so confused because everything is acting normal until I try to start it. The image is a clip (I believe) that fell off when I started taking the column off and not sure where it goes?
Mar 1, 2018 at 11:07 AM
  • 55,748 POSTS
Can you take a quick video of the problem so I can see whats going on? That way I can tell for sure whats up. You can upload it in your response.
Mar 2, 2018 at 2:11 AM
