No crank no start
80,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
STEVEJSCOTT
Battery good new ignition switch, new starter,replaced BCM and ECM. pass-lock light comes on then off right away.with the key in off position I have 12v to the white wire and orange . any advice?
Apr 1, 2020 at 7:36 AM
Good evening,
I attached a wiring diagram for you to view.
Do you have a test light or volt meter to do some checks at the starter relay?
Apr 1, 2020 at 8:23 AM
STEVEJSCOTT
relays and fuses are good.i have voltage at white wire and orange wire (of the ignition switch)
but when i turnkey to start all lights stop working, no sound.nothing. is this a pass-lock issue?
Apr 4, 2020 at 8:46 AM
How did you test the relays and fuses?
The diagram I sent you need to test The purple wire at the starter solenoid for power in the start position.
Apr 4, 2020 at 9:24 AM
