No Crank, no start
2009 MAZDA RX8
65,000 MILES • 1.3L • 2WD • AUTOMATIC
TYLER SEIBERT
So my car is having some issues starting, at first the battery light had come on. So I brought my battery into the Autozone near where I live, they tested the battery and it was dead. So i got a replacement for it, the car was fine and then started to do it again. I figured that the alternator was not charging the battery or I had a bad grounding wire. I went through the maintenance manual and found all the grounding areas in the engine bay, i cleaned them up and replaced the alternator, and got the belt tightened. upon doing so. The car wont crank, turn over, or make any noise when trying to start the car.
Oct 28, 2016 at 6:46 PM
RENEE L
  • CAR REPAIR CONTRIBUTOR
  • 1,260 POSTS
Hi TYLER,
While you are waiting for a response from one of our experts here is a link to an informative article from this site with step by step instructions and photographs on what to check for when your vehicle will not crank over.
I hope this helps you. Thank you for visiting 2CarPros.com.
https://www.2carpros.com/articles/car-engine-will-not-crank-over
Kindest regards,
Renee
Admin
Oct 29, 2016 at 3:05 PM
