The car listed above is a coupe with a no start no crank condition. When I turn the key to the position all dash light lights up. When I turn to start, nothing. no clicks no nothing. Battery is good. I was thinking starter bit when I tried to jump it with a jumper wire and found out there's no power to starter relay. Another thing is the blower motor does not work and headlights do not come on. My next step is to check 125-amp alternator fuse. But with test light it has power. Eliminated usual suspects bad relay, battery. Could it be the ignition switch?
And why is there no power to starter relay? Could it be the neutral safety switch? At a loss. Please help.
Nov 22, 2022 at 8:56 AM
