No power to the starter relay. Starter relay has power from battery. Key switch has power. I was assuming the ignition switch went bad, but the truck stayed running once it started. Ignition switch and starter relay are 2 years old. Will only start by jumping starter relay 2 big posts with screwdriver. Will not start by jumping big post to S post. I believe the key switch actuator rod has broken; I've been pushing the rod to the ignition switch to start. I have a push button starter I was planning on installing in the near future, since the OEM key switch is worn. Any ideas would be greatly appreciated. Thank you.
Apr 1, 2025 at 12:06 PM
