no crank no start
20,230 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
PAPIDELEON56
Replaced my battery and I pulled the starter out, took it to get it checked and it passed. I put it back together and still no crank no start. I checked the fuses used a test light nothing bured when I turn the key on everything works lights, horn taillights front lights wipers turn signal, and when I turn the key on I can hear a clicking sound by the intake housing and goes off about one second after I turn the key on then shuts off. This is the only vehicle we have, and we live out in the country about 8 miles out. Thank you if you could help.
Dec 23, 2021 at 10:30 AM
Good morning,
I attached a wiring diagram for you to follow.
Check the two fuses I circled for power. Check both sides of the fuse.
We need to do pinpoint testing to find the failure.
Does the anti-theft or security light go off after about 10 seconds with the key on?
https://www.2carpros.com/articles/how-to-reset-a-security-system
Dec 23, 2021 at 11:16 PM
PAPIDELEON56
Hello, i checked everything but still no crank no start?
Jan 1, 2022 at 11:34 AM
Can I have the results of the information I requested?
Jan 2, 2022 at 6:55 PM
