No crank no start
100,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
RANDY1955
  • 71 POSTS
The red is blinking for the anti theft system. no crank no start. how do I reset it?
Nov 5, 2019 at 4:55 AM
BMDOUBLE
  • 1,139 POSTS
Does the service engine soon light illuminate when you turn the key to the run position (second click)? The power-train control module codes need to be retrieved in order to follow the correct diagnostic routine. There is no simple reset. It could be anything from a bad key, faulty PCM power relay, PCM, transceiver ring, but to pinpoint it we need the codes.
Nov 5, 2019 at 6:23 AM
