No crank no start
162,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
IMPALAMIKE
Engine shuddered and now won't start.
Jan 15, 2021 at 11:14 PM
Good morning,
The first thing to check is the battery. Make sure it has 12.6 volts so there is enough power to crank and run the engine.
Next, I would make sure the engine turns. Try and turn the engine manually to be sure it turns.
I attached a wiring diagram for you of the starting system. We need to do some voltage checks for the starter to be sure it is good.
Mar 6, 2021 at 9:50 AM
IMPALAMIKE
Just put in new battery lights work everything's on and again just 1 click.
Okay, can you go to the relay and do some testing for me? We need to see if there are any signals to the relay.
