No crank no start running after sitting for a year?
160,000 MILES • V6 • AUTOMATIC
FRANCIS DUPREE
Hey guys, have the vehicle listed above that I recently got up and running after sitting for a year. Everything was fine with a little tune up. I got up, drove to the store, forgot some so I started to head back out. I go to start it and nothing. No click has power in fact the power won't turn off even without the key engaged. Also, I believe the little red dot stayed on. After researching what that was, I followed a prompt to pull the fuse that comes out but stays housed and wait five minutes. I did that and the light went off. Still nothing. When I bypass the relay, it cranks but doesn't fully turnover or start. Had to disconnect the battery to turn offf all power. Any advice?
Dec 30, 2024 at 8:33 PM
  • 55,865 POSTS
Yep, it sounds like the IPM has gone bad which is common on these cars. You may want to try a CAN scan which could help confirm the issue. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Here is how to change out the IPM which is easy because it-self learns. Check out the images (below). Please let us know what happens.
Jan 1, 2025 at 3:41 AM
