No crank no start
40,000 MILES • V10 • 2WD • AUTOMATIC
HOWELL SHARON KING
Van listed above is a E450. where odometer should be it says "check gauges" when this shows up all I get is a click.if this shows and goes off it will crank but no start. if you turn switch on and odometer lights up it will start as normal but most of the time it will do nothing afraid to leave home with it.
Apr 21, 2021 at 7:51 AM
Good evening,
I would start by cleaning the battery cables. You could have low voltage which would explain the message and the click.
I would also check the battery as well.
Apr 21, 2021 at 8:45 AM
