No crank no start
134,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
DONATO68SS
  • 16 POSTS
The timing chain broke and destroyed the motor. I installed a re-manufactured engine. Now I have a no crank no start issue. I have power ie, lights on dash but turn to start and nothing no engaging of the starter. All worked before. I did notice that that ABS light is on traction control light is on and numerous other things are coming up on the display. Also the fuel gauge reads completely empty and I know that’s not right either. I checked fuses and relays and all are good. Can someone point me in the right direction? Oh one more thing I plugged in my hand held code reader and it could not communicate with the car.
Mar 29, 2020 at 10:15 PM
Good morning,
Can you test the battery voltage? It needs to be 12.4 to 12.6 volts.
The key may have forgot the password for the security system. I will attach the procedure for you to reset.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Key with Integrated Transmitter Programming
Keys can be programming in various ways using the procedures outlined below. Using the Replacing Keys procedures will first erase all the known keys from the vehicle. Any existing keys and any new keys will then be programmed. This procedure should be used any time a key is required to be unlearned or erased from a vehicle. If a new key is being learned to a vehicle to replace a damaged, inoperative, or stolen key, the Replacing Keys procedure must be used. This ensures that the old key cannot be used to access or start the vehicle after programming.
The Adding Keys procedure does not erase any keys prior to programming. The procedure will simply program the key into the next available slot. The Adding Keys procedure should only be used when adding an additional key to the vehicle. The Adding Keys procedure should never be used to program a key to a vehicle that is having a key replaced, regardless of the cause for the replacement.
Mar 29, 2020 at 11:23 PM
DONATO68SS
  • 16 POSTS
I have tested the battery and it is fine. I’ll try resetting the key next.
Mar 30, 2020 at 3:02 AM
  • 55,797 POSTS
No communication? can you please try the scanner on another car to see if it works? , if so lets check the system fuses. here is a guide and the fuse panel locations make sure the key is on. Also when you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds?
Mar 30, 2020 at 4:06 AM
DONATO68SS
  • 16 POSTS
Yes, I have checked the scanner on my other car and it works fine. I do not hear the fuel pump run when ignition is on. I have checked every fuse also.
Mar 30, 2020 at 4:10 AM
The fuel pump will not come on if the key does not give the password.
The spark and fuel will be disabled and not allow that operation.
Mar 30, 2020 at 5:09 AM
DONATO68SS
  • 16 POSTS
I haven’t tried the key re-learn yet. I will as soon as I’m at the car. Thank you guys.
Mar 30, 2020 at 5:21 AM
You are welcome.
We are always glad to help.
Mar 30, 2020 at 5:35 AM
DONATO68SS
  • 16 POSTS
I do have a question about the re-learn. The fob that holds the key the unlock and lock buttons work along with the panic button. Do I still need to do a re-learn?
Mar 30, 2020 at 5:50 AM
That is for the fob.
The key relearn is a 10 minute reset.
Turn the key to on and turn to start. then release back to the on position. Let it sit for 10 minutes. The security or theft light should go out.
Do this 3 times. After the third time, the key should have learned the password.
Mar 30, 2020 at 6:04 AM
DONATO68SS
  • 16 POSTS
Okay, I tried the key re-learn with no luck.
Mar 31, 2020 at 9:49 AM
Okay, then you will need to follow the charts that Ken left you a ways back.
Mar 31, 2020 at 9:50 AM
DONATO68SS
  • 16 POSTS
Thanks Roy.
Mar 31, 2020 at 10:36 AM
You are welcome.
Feel free to ask any follow up questions.
Mar 31, 2020 at 10:38 AM
DONATO68SS
  • 16 POSTS
I got the car to crank by jumping the starter solenoid with the 30 and 87 pin. I have checked all fuses. I got a hold of another scanner but still can’t communicate with the car. Any other suggestions?
Mar 31, 2020 at 11:13 AM
You just bypassed the relay. The ECM is preventing it from starting due to the communication issue.
Mar 31, 2020 at 11:16 AM
DONATO68SS
  • 16 POSTS
Do you possibly have the wiring schematics for the starter?
Mar 31, 2020 at 11:53 AM
Diagram attached.
Let me know if you have any other questions.
Mar 31, 2020 at 12:02 PM
