No crank issues
137,000 MILES • 2.8L • 6 CYL • 2WD • MANUAL
THOMAS LEONE
I am working on a friend's vehicle. I was told it ran great until one day last week it quit turning over...i replaced the clutch pedal sensor and it fired right up. Two days later he tells me that the same thing is happening. There are no blown fuses and all the wiring is in great shape. I was thinking it could be the ignition switch. Thanks
Feb 19, 2017 at 3:44 AM
CJ MEDEVAC
  • 11,000 POSTS
What about this EZ/ dumb/ overlooked stuff?
See my answers in this link and it's pics at the end.
https://www.2carpros.com/questions/1996-chevrolet-tahoe-wont-start-sounds-dead-battery-jumpbox-get-same-reults
Return with good news!
Feb 19, 2017 at 4:39 AM
THOMAS LEONE
I checked all the connections and the battery terminals were the worst. But after all that all I'm getting is a single click from the distributor/solenoid. Still no crank.
Feb 20, 2017 at 1:24 AM
CJ MEDEVAC
  • 11,000 POSTS
I grabbed your starting system diagram from "Prodemand"
Pretty simple
Possibilities can only be (worst 1st)
Engine locked, will not move (With the KEY OFF, can you do 2 crankshaft revolutions with a ratchet or wrench-see pic below of my Jeep engine)
Bad starter or starter solenoid (remove and have tested at a parts store)
Clutch start interlock (disconnect and TEMPORARILY jump across the connector)
Weak or bad battery (even a new one can be bad-pull it and have it tested at an auto parts store)
Engine control system fuse
Connections
The Medic
Feb 20, 2017 at 10:32 AM
