starter not working?
95,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
MELISSA CEDENO-CROWTON
replaced battery, alternator, starter. Still won't crank. Only a clicking noise. All lights and dinging sounds work, etc. No signs or symptoms leading up to this. Did blow a fuse the day before to my cigarette lighter. Please help! Could this be my relay??
May 19, 2021 at 12:08 PM
  • 55,732 POSTS
This happens when the TIPM module goes out which is common but it is easy to replace because it self initializes. Just in case here are two guides to help us see what's going on the the starter wiring diagrams so you can see how the system works with the TIPM replacement instructions as well:
and
May 20, 2021 at 12:20 PM
