This vehicle doesn't have a traditional starter relay. In its place is a circuit board that is integral to the totally integrated power module (TIPM).
Have you tried starting it in neutral? There could be a neutral safety switch issue.
Anyway, I attached the wiring schematic for the starting circuit. I highlighted what has taken the place of the relay. What I need you to do is have a helper turn the key to the start position while you check for power at the yellow wire with a white tracer on the starter.
If you find there is no power, let me know. We will need to check for power at connector 10 pin 8 at the TIPM. I you feel comfortable, do that as well and let me know the results.
Let me know what you find.
Take care and Happy New Year,
Images (Click to enlarge)
Dec 31, 2022 at 10:28 AM
