No crank
250,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
MARK UNDERWOOD2
  • 24 POSTS
New starter, new battery, no crank, only clicks one time. cleaned cables.
Aug 1, 2020 at 11:21 AM
  • 110,248 POSTS
Have you made sure the main ground to the engine block is in good condition?
If so, I need you to check for power to the purple wire going to the starter solenoid. It will only have 12v when the key is in the start position. You will need a helper to check that. Also, reconfirm that the wires on the new starter are tight.
I attached a pic of the wiring below. Just for the heck of it, see if it starts in neutral. Also, take a look through this link. It explains how to test the starter.
The idea that you get one click usually indicates either a weak battery or a poor connection. Since you have already replaced both the starter and battery, I have a feeling it is a connection unless there is a chance the engine is locked up.
Let me know what you find.
Aug 2, 2020 at 3:03 PM
MARK UNDERWOOD2
  • 24 POSTS
Thanks Joe, cleaned ground mounted on stud on intake and it turned over and started faster than I ever heard! I drove it 14 miles with no accessories on. Turned off engine and it started right up. Let it sit 2 minutes.. no start (engine turnover) again! Only 1 click now?
Aug 3, 2020 at 6:26 AM
MARK UNDERWOOD2
  • 24 POSTS
Also I have tried starting in neutral with negative results.
Thanks
Aug 3, 2020 at 6:28 AM
  • 110,248 POSTS
We still have a weak connection. Do me a favor. I need you to disconnect the negative battery cable from the battery. Check it for continuity to ground, which I know you will have. While checking it, move the wire around to see if the resistance changes. I'm starting to think the wire may have internal damage and making good connection on and off.
Aug 3, 2020 at 3:54 PM
MARK UNDERWOOD2
  • 24 POSTS
Hi Jo! Checking for continuity to ground? Do you mean with an ohmeter? If so we might have a problem for I don't have. sorry......
What is it that the main ground goes to? It goes from battery to some tiny fitting on intake????
Aug 4, 2020 at 9:12 AM
  • 110,248 POSTS
Yes, you need a multi meter to check for continuity. Don't worry. We'll figure a different way.
As far as the grounds, from the battery there are two. One of them goes to the engine block and the other is grounded to the inner fender close to the battery. See the attached pics.
Aug 4, 2020 at 3:25 PM
MARK UNDERWOOD2
  • 24 POSTS
Hey Joe, disregard the statement about the tiny fitting on ground cable for I guess I am okay, old and blind! Lol The fitting I was referring to was not a fitting at all! It was a ring terminal mounted on stud! Wasn't very dirty but cleaned it anyway and viola! Engine turns over, runs, etc.
Great job Joe!
PS. do you think 2 distributor's, 2 alternators, 3 batteries, and 2 fuel pumps we're replaced simply because of bad ground?
Thanks
Aug 5, 2020 at 10:31 AM
  • 110,248 POSTS
First, you are very welcome. I'm glad it's running again. Now, I don't want to say it, but anything electrical could have been affected by the ground. I didn't realize that many things had been replaced.
Let just say everything was needed. LOL That will make it easier to deal with. LOL
Listen, please feel free to come back anytime you have questions in the future. You are always welcome.
Take good care of yourself.
Aug 5, 2020 at 4:03 PM
