No crank after replacing the intake gaskets?
211,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
DANIEL BENNETT2
Car ran fine. It had an intake leak; I removed the intake and replaced all the gaskets. It was all back together. now it won't turn over at all. The battery is good, the starter is good, everything is good. The wiring harness is all plugged in and rechecked all of that fuses are all good.
May 15, 2024 at 8:10 AM
  • 55,694 POSTS
Let's see if the engine will turn over manually. This guide can help, my fear is something when down into the intake port and is now stuck on top of the piston.
Please go over this guide:
https://www.2carpros.com/articles/engine-seized-test
Please go over this guide and get back to us.
May 16, 2024 at 5:19 AM
