Codes P0562, p0123, p0222, and p0113, engine does not crank and the check engine light flashes?
170,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
STARGUY
Lightning bolt on the dash. Check engine light blinks 4 times then stays steady. Replaced battery, and alternator. Starter checked good. Turn the key and nothing. Everything is on. Radio, blower motor. All on. I have these 4 codes showing. P0562, p0123, p0222, and p0113
Nov 16, 2023 at 11:58 PM
  • 55,658 POSTS
Here are the code definitions and it looks like the TIPM is not working which is common.
P0562 - System Voltage Low: This code suggests that the vehicle's electrical system is operating at a voltage level lower than expected.
P0123 - Throttle/Pedal Position Sensor/Switch 'A' Circuit High:
P0222 - Throttle/Pedal Position Sensor/Switch 'B' Circuit Low:
P0113 - Intake Air Temperature Sensor 1 Circuit High Input: This code means that the intake air temperature sensor is reporting a higher than expected temperature.
Here is how to change the TIPM out which is easy because it self learns.
TOTALLY INTEGRATED POWER MODULE (TIPM) - REMOVAL
REMOVAL
1. Open hood.
2. Disconnect and isolate the battery negative cable.
3. Release the Totally Integrated Power Module (TIPM) cover retaining clips and open the TIPM cover.
4. Remove the TIPM positive cable retaining nut and remove the cable from the stud.
5. Depress the four mounting clips to disengage and remove the TIPM housing from its mounting bracket.
6. Disconnect each of the seven TIPM wire harness connectors.
7. Remove the TIPM from the vehicle.
INSTALLATION
CAUTION: The original Cabin Compartment Node (CCN) and Powertrain Control Module (PCM) must be installed and functioning properly prior to powering up the new Totally Integrated Power Module (TIPM). The TIPM receives vehicle configuration data from the CCN and Vehicle Identification Number (VIN) information from the PCM. If configuration information becomes lost or corrupted, the data can be obtained from DealerCONNECT
1. Position the TIPM into the engine compartment.
2. Connect each of the seven TIPM wire harness connectors.
3. Position the TIPM positive cable onto the mounting stud and install the retaining nut. Tighten the nut to 9 - 11 Nm (80 - 100 in. lbs.).
4. Position the TIPM onto the mounting bracket and push down until the mounting clips are fully seated.
5. Open the TIPM cover and fully seat the Airbag fuse holder (two fuses in one yellow carrier) and the Ignition Off Draw (IOD) fuse.
6. Connect the battery negative cable.
7. Close the hood.
8. Insert the ignition key and turn it to the "RUN" position and wait twelve seconds. The TIPM will collect the necessary vehicle configuration and VIN data from the CCN and PCM at this time. After twelve seconds turn the ignition key to the "OFF" position and then back to the "ON" position and verify proper vehicle systems operation.
Clear all codes once the repair is completed. Check out the images (below). Let us know how it goes.
Nov 17, 2023 at 6:55 AM
STARGUY
Thanks Ken. I am ordering one today. I will get back to you when the part arrives.
Nov 18, 2023 at 1:39 AM
  • 55,658 POSTS
You are welcome, let me know how it goes.
Nov 18, 2023 at 1:40 AM
STARGUY
Yes, I am still interested. Hi Ken. Sorry it took me this long to respond. I purchased a TIPM. Its installed. And the car is running. Before the car sat, there were no lights on. Now with the new TIPM I has the Brake light on steady. And I also have the traction control light on. And I cant turn it off with the button. I did a hard reset before I bought the part. The car started and ran. But the wipers were going on there own. Does this mean the TIPM i bought is no good?
Dec 6, 2023 at 10:57 AM
  • 55,658 POSTS
yep, it sounds like the TIPM is defective, can I ask if the TIPM is new or a used part?
Dec 8, 2023 at 1:51 AM
STARGUY
Ken.
Here's where I'm at right now:
The ABS and Traction control were already on. I'm having that looked at as soon as I get this situation resolved. So, the only thing that's not right at the moment is the parking brake light coming on. Could it be something with the parking brake? Because when I took it down off the jack stands it released kind of hard. If that makes any sense. Other than the parking brake light being on, it's running and braking fine.
Ken, I also wanted to add. I noticed on a couple of occasions that my speedometer was reading 0 as I was going down the road. It hasn't done it since yesterday. The TIPM is used.
Dec 9, 2023 at 12:40 AM
  • 55,658 POSTS
I am not a big fan of a used TIPM because they have such a high failure rate. Also, for the brake warning light check the level of the brake fluid which can cause the brake warning light to come on. The fact that TIPM has changed, and it fixed most of the problems means we are getting closer. You might want to try just driving the car around to see if the TIPM can learn more and solve some of the remaining problems after a couple of drive cycles.
Dec 9, 2023 at 2:48 AM
